kryptonite850
Thread starter- Joined
- Jun 26, 2010
- 20
This is probably going to be wordy and I appologize right off the bat, but I have done a bit of troubleshooting and want to include this information so you get an accurate description.
Here goes...
I bought a 1988 Mirrocraft 20ft openbow with an Evinrude 120 (E120TLCCA). I knew it ran with a bit of a miss, so I got the deal I wanted. Now, before replacing the outboard, I want to see if I can get her running right. (I'll just keep the motor on it if I can).
So... what's going on?
Right off the bat, it had a rough idle. I ran it around a local waterhole and when accelerated, it smoothed out. I ran it for about 20 minutes and then it died (thought maybe impeller along with some other idle issue). It was pumping water fine though and the dang thing wouldn't start until I pushed the key in for the choke, then it would start up and idle rough, but start the whole process over again.
I pulled the air cover off and saw that the lower left carb was puking gasoline. It appeared milky. My thought was stuck float and possibly water in the gas. I ordered a rebuild kit for the carb.
I then hooked an external fuel tank to the outboard. This is a clean tank and I put fresh out of the pump gas in it. I pumped out the VRO reserve and put some fresh 2cyl oil in it. I removed the fuel filter and replaced it with a straight through piece.
My carb rebuild kit came! I rebuilt the carb, following the Seloc manual. It quit puking gas! I was happy, but while it smoothed out a bit, it still has a slightly rough idle. It will run great for about 10-15 seconds and then trip over itself for about 10-15 seconds. Then repeat.
I ran a compression check on it and found all 4 cylinders to pump up to 120 and hold fine.
I checked the spark with a basic spark tester (arc style). The spark looked strong and consistent.
I read somewhere that these things will run on 1 cylinder. Probably not smart to do much, but I wanted to find out which cylinder was having issues. I started the motor and pulled each plug wire individually to see what happened. The varying rough idle continued until I pulled the plug wire for the same cylinder that I rebuilt the carb for. When I pulled this wire, it smoothed off pretty good (as smooth as you would expect for running on 3 cylinders), with no more bucking motor.
Found my suspect!
Next, I pulled all the wires off of the plugs and tried each cylinder one by one. It would start on a single cylinder and run briefly on each cylinder, except the one that I rebuilt the carb on. HMMMMM....
I swap the sparkplug with one that was in a good cylinder, no change. I swap the plug wire, no change. I swap the coils, no change. ARGGG... I use the push to choke and that cylinder fires up. Ok, so now is it a weak spark that needs the raw gas or is it not getting fuel?
I unplug all plug wires and crank the engine for a few seconds. I check the plugs and find the problem cylinder to have a damp plug. I wipe it off and wipe off the one above it, then put them back in. I crank the motor a few times and pull the plugs again. Again, a damp plug, but it looks a bit more dry than the one above it. Not much more though.
Back to "maybe I screwed something up in the rebuild, but I really don't think so". The carbs are identical, so as a drastic measure and I HAD to know, I swapped two of the carbs. I really expected the problem to move to the new cylinder for that rebuilt carb. NOPE! Problem stayed in the same cylinder. Eureka! It's electrical! or not...
So I start reading a bit more and come across the reed valves section in the Seloc. Sounds kinda like what is going on. I hold some folded up computer paper infront of each of the carbs and get NO gasoline blowing back through ANY of the carbs. Makes me think that is not the problem. Hmmm... back to electrical, but it's not anything from the coil through the sparkplug.
Any idea what is going on with this motor? Any help would be GREATLY appreciated!
Here goes...
Found my suspect!
