Justinde
Thread starter- Joined
- Dec 11, 2010
- 431
HI All ( again)
My 1988 125 has a coupe of issues which I am fairly certain caused by an incorrect adjustment on the forward controls.
There are a couple of issues, so I'll list them so as to paint a better picture and hopefully get a resolution to my problem.
* Idle speed screw on tower at lowest adjustment but engine still idles fast
* If I'm not careful, she will go from forward straight to reverse- and the forward control is stiff
* The tower shaft arm and neutral stop arm don't seem to be adjusted properly
* Engine coughs and sputters a bit at idle, but hole shot is OK
* Engine can be a ***** to start, cold or hot, but once it's running it seems OK, just the coughing out of gear at idle.
So now, over to the experts. Can the forward control cables be adjusted and would this be the cause of some of if not all of the above problems?
Cheers
Cheers
