reelmasta
Thread starter- Joined
- Apr 8, 2012
- 18
Having problems with my 125 at idle. It works fine until I put the cover on and then it dies. I had it out this evening with the intent to adjust the carbs because last time out it wouldn't idle for me. So I took the cover off and it idles fine. Tied to the dock it goes fwd and rev and back to idle nicely. Throw on the cover and it seams like it's starving for air and dies. Take the cover back off and presto runs good again. So I took it out on the lake with the cover off for the first time and it jumped right up like it never has before and ran like a kitty. Shut her down and put the cover on and same issue as at the dock and dies unless I jam it into gear. When I did jam it into gear and give it WOT it runs like it always has and takes a while to plane out and then seams to do ok. But my goodness with the cover off it runs like a raped ape.
It has idled ok in the past with the cover on but has always labored out off the hole like a pregnant lady walking up the stairs...
Any suggestions?
Any suggestions?
