Re: 1988 force 85 hp tune up
You're new to boating? Welcome to the forum. What kinda boat?<br />If it has been in storage, then get a can of decarb cleaner. spray some into the carb.<br />Remove the plugs,and pray some in the holes.<br />Submerge the motor in a large drum of water, to just above the cavitation plate (fins above the prop).<br />crank it over until the plug holes quit spitting cleaner,and replace the plugs.<br />Clean the fuel tank,and put fresh 50:1 mix<br />in. Pump up the primer and see what goes. or doesn't.<br />Let us know if it doesn't run for you.<br /><br /><br /><br />------------------<br />the Early bird get's the worm...So, he don't have to stop for bait.
