O.T.Water
Thread starter- Joined
- Sep 12, 2009
- 88
So yesterday I did the impellar, it was shot and that was a success. Then I did the fuel pump and was very careful to get the valves and diaphram in correctly. I do have a Clymers and have read many threads here. It fired right up on the muffs so I went to the river this morning. I noticed a slight hiccup or backfire at idle a couple of times, it had never done that before. Went to WOT ok and backed off to cruise for 10 minutes. Slowed down and it died! No fuel in the ball. Pumped the ball and it finally got hard(long time) it started but died when I tried to go more than idle in gear. It was very hard to start again and when it did we limped back to port. It wasn't running on all cyls. and would not run anymore than just above idle speed. Pulled the plugs and they all look alike. 1 and 3 cyls look wet but 2 looks dry. One other thing, when I got home and ran it on the muffs I notice a little grey milky goop coming out of the exhaust fin with the water. Is that normal, I had never noticed it before.
