1988 force 85 wiring?
Cyrus02
Could someone please send an image of the wiring of a 1987-1991 Force 85, the one I have has some wires not hooked up from the previous owner, and I would like to know where they need to go.
Even a service manual would be helpful, Thank you.16890225739218590087802597637110.jpg1689022695202962559018998757540.jpg16890229651215337434148135673214.jpg
Nordin
Check out Master Tech Marine, they have wiring diagram for 4 cylinder Force with Prestolite ignition system.
Your engine has 3 cylinder but the wiring is the same except for one cylinder less.
BTW Your engine has an ignition mounting plate from a 4 cylinder engine.
Pre owner might been messing with it.
The Force power
Here's the wiring for the 3 cylinder disregard all other wires on your motor as Nordin said; it is set up for a four cylinder
Also the Flywheel nut is missing; check for the key
Cyrus02
My guess......random parts thrown on to sell as "complete"
Got it as a deal with a boat and trailer for $1000, along with another parts motor that has no compression on one cylinder.
Previous owner was drunk when throwing this together, so my hopes arent so high with this engine.
