TimberwolfFXDL
Thread starter- Joined
- Oct 17, 2010
- 38
This is the boat/hull design:
Here is the only information on the prop I can find:
http://www.timberwolfperformance.com/images/1988bayliner/IMG00034-20101017-1553.jpg
Best I can gather from google, it's a 13x19 Michigan Wheel. Sound right?
It's got a chip missing from one blade, and a crack in another. Considering the max rpm (water was fairly smooth, 3 passengers totalling 450lbs, no real gear to speak of) was only 4800, and adding in the repair needed to the prop, I'm thinking I might as well replace the prop, so while I'm at it, maybe drop a bit in pitch.
Would a 17" get it where it should be? I've read 5200-5600rpm is the range for these motors, and that each step in pitch is worth 300-400rpm. Or should I go for the 15"? I don't need ultimate top speed, but I'd like to get moving quickly for pulling a skier or tube. That being said, a reduction in pitch, but a 15% increase in RPM would effect my top speed how?
Any recommendations on prop?
PS: the motor seems to run out smooth, plugs look great, etc.
