WaveJumpingMaxum
Thread starter- Joined
- Jun 28, 2011
- 84
ok i took all 3 of my carbs off for general mantience. unbolted throttle cam, and turned throttle roller wide open to acess the bolt on bottom carb. put everything back on , chokes synced perfectly, throttle was good too or so i thought. started boat on muffs had no throttle at all in pull out away from gunwale to disengage gear neutral. when i go wide open in gear the carbs opened maybe 3/4 of the way. all 3 equally and easily.if i throttle by hand turning the carb i all 3 carbs open equally and easily. i have adjusted the throttle cam and roller to where they open fully horizontal in wot in gear nd to the back point where they only open 1/4 of the way wot in gear, still whatever i do i cannot get them to open in nuetral. my questions are, how to check if its the throttle cable or control box? the control box in pulled out nuetral only seems to grab the throttle in the last 1/4 push it has before stopping. us marine style 1989 maxum bowrider if that makes a difference. is there a test like unhooking the cable from the back of the control box and trying to open the throttle that would tell me where to start?
