1988 Imperial 280sf engine swap and restoration (pics)
zool
Re: 1988 Imperial 280sf engine swap and restoration (pics)
No problem with loose joints now . ;)
Are they gunna fit in the jambs with adding the extra glass around the edges ? I guess you could have trimmed the edges down a bit to allow room for the glass. Or was they set in a jamb ?
Yep, shes a solid frame door now lol
The door sets in a groved teak partial jamb, Sam....it works just like any bifold closet door, where it almost closes, then snaps into place...The teak jamb need sanding anyway, so i figure ill leave it tight to test fit, then sand the jamb groove just enough to get it snug again.
No science or measurements, ill just "work" it til its right.
The close down lid will be next, another tricky endeaver because its broken.....more on that later.
Woodonglass
Honorary Supreme Mariner
Are you gunna paint the doors white?
zool
Yea Mike, same white poly as the cockpit and topdecks...im whiting out most everything including white pleated cushions, just leaving some teak accents and the swim platform.
zool
I couldnt work on the door today, it was still tacky, so I made some new tenons for the other door, assembled and glued/clamped it. Just letting it set up now.
when it cures ill fill the voids with pb and continue covering both.
tpenfield
Keeping the old style woodwork looking good on a boat is always tough. So, it is good that you are glassing the doors. These new ones that you showed as an example . . . I am wondering if those are Lexan or something like that?
zool
Yea, refinishing and maintaining those teak doors would be a chore at best...i'd bet the doors in that pic are a composite mold, but I dont have the ability to make a multi dimensional seamless door frame like that, this is the closest i can reasonably expect, based on my skills.
Now the cabin, on the other hand will be all wood vaneer, with a teak and holly sole, and cream soft goods. This is about the same size and layout of mine, and this is the look im going for.....ill be busy for a while :)
archbuilder
I think you should paint the door red, give her some bling :D
bigdirty
nah, paint it pink! (and hang an old timey neon light above the cabin door 'girls girls girls' :laugh:)
That is gona be one nice lookin boat in the end man! I'm hoping to go for a similar theme in my cabin, maybe not AS much wood work, but defiantly the floors and 'lighten up' the existing teak/wood trim. Gives it a crisp newer look.
Woodonglass
If you can put a final layer of 3oz on top of that 6oz ( it looks heavier to me) so the weave won't bleed thru. If you don't have any then you'll need more resin to fill the weave but you already know that so I'll shut up and go away now!!!!:sleeping:
zool
If youre refering to the unwetted cloth pic, thats the 8.9oz eglass, good eye ;)...i know the thread doesnt read that way...the wetted pics are what i think is 6oz...its just the cloth from HD next to the 3m poly resin..whatever it is, it shapes well
Bondo? Fiberglass Cloth, 8 Square Feet, 20128
I was planning on filling the weave with a skim coat of west 410, then another coat or two as sacrificial, to sand level.
zool
Arch, I do have some of that electric blue from the shop cabinets lol
BD, Pink is an exclusive bayliner color, I couldnt do that to you man :D.....a neon GoGo sign is interesting tho lol
Jayboat66
Nice job, I can't wait to see the final product. The boat will be better than new from the factory.
bigdirty
ACTually.. i was having a laugh with my buddy about this whole 'pink' thing.. and oh, oh no..... yup, his 94 FORMULA 31pc has a BIG pink stripe down the hull, and pink is mixed into all the upholstery.. :tongue: I dono if it can be said to be an 'exclusive' color for bayliner.. but no mater what its on, I still think it looks silly :lol: blue and white for me all the way..
archbuilder
sounds like a Miami Vice hangover, lol!
tpenfield
Did somebody say "pink stripe down the middle" and "Miami Vice"? :noidea:
I call it 'magenta' . . .
zool
Thanks jay, and welcome aboard. Yea, I think any one of these restos here will be better than the factory...because we do it for ourselves :)
zool
And guys, im joking, there were alot of interiors back then that used pastels, and im sure there were alot of captains sitting in the lounge bragging that their upholstery shines as bright as their shirt :D
And i remember plenty of pink on my decks, as the guys bled the tuna....good times back then.
And Ted, in any color combo, that SS is a purty girl......
Woodonglass
Alrighty Then!!!! I kinda thought the pics looked different between dry and wet out. Sounds like I had my nose stuck where it didn't need to be!!!! Carry On!!!!:D
bigdirty
:lol: yup, pretty much the same color scheme on my buddys 31pc, although hes got a bit more green in the decals.. and either way, you can 'get away' with it on your boat.. cause, well.. it IS a Formula.. :wink:
Cellotbp
Man she sure is looking good, ive started work on my 84 28ft Bayliner pulled he out about 2 weeks ago, just cleaning her up right now to be able to see in which direction i should be headed first.
Her hull and body is in pretty good shape but the motor is blown that really sucks. That i was gonna be able to just a rebuild. Im sure hoping mine tun out as good as yours is looking.
