1988 Johnson 40 hp VRO (What is the best possible spark plug?)
JohnnyRuuDe
I recently learned that JOhnson recommends the use of Champion's "QL" type spark plugs for use on all VRO models. Is this info up-to-date? Is there a superior replacement. I know they do a great deal of testing to determine the best spark plug but the specification chart I read is only current as of 2007. The guy I bought it from had regular plugs in there and said it misfired at high rpm but he wasn't sure why...hhmmm. Also, does this engine have a charging system...i'm clueless and any help would be cool. Thanks -Lewis
steelespike
Re: 1988 Johnson 40 hp VRO (What is the best possible spark plug?)
My info says Champion QL77JC4 for normal operation,QL78V for sustained high speed operation.
tashasdaddy
correct, NAPA autoparts even has a note on there computers, that anything but champions, have been known to cause missfires in Johnson/Evinrude outboards.
JohnnyRuuDe
Thank you gentleman..I appreciate your help. Lewis
Silvertip
Honorary Supreme Mariner
Yes -- the engine has a charging system.
JohnnyRuuDe
Thanks Silvertip, good to know! Any Idea what kind of charging voltage I should be getting out of the engine, I'd like to check it.
