ct1762@gmail.com
Ensign
- Joined
- Jan 17, 2019
- 963
I rarely get stumped, but hopefully one of you can give me some pointers. Got this motor in (j50BELCCD) and has hot blue 1/2'' spark. went through the usual ignition tests with DVA meter to make sure everything was good. well, tested primary coil output from the power pack to coils... waaa waaa only 3-4v when it should be over 200v. Suspected sensor coil... it was going to ground. replaced sensor coil with a known good one, and same thing3-4v at pack! then replaced the pack with a brand new one. same thing 3-4v. then got another good pack and same results (pack #3). checked and cleaned all grounds. nothing. then removed the flywheel and put another one on in case the original one had weak magnets (it was fine). nothing. still only 3-4v. I tried 2 different meters and both show the exact same reading! the charge coil is only putting out 45v when it should be 230v cranking, but fail to see how this would effect power pack output. ditto for disconnecting yellow wires at rectifier. but did it anyway and same results. the only thing i didn't do was disconnect the black/yellow stop wire at the pack. could that be causing these low readings? the odd thing is the spark is really blue and strong, with a big "snap". engine runs, too, but havent gone through the carbs yet so didn't want to run it long. any ideas guys?
