dingbat
- Joined
- Nov 20, 2001
- 17,238
continuousWave: Whaler: Reference: VRO Fuel-Oil Mixing
OMC VRO fuel-oil mixing in outboard motors
continuouswave.com
OMC VRO fuel-oil mixing in outboard motorscontinuouswave.com
Going on year 28 with my second "VRO" pump.Now I want you to do a P M inspection every year of all those parts. In areas with freezing weather. Atta boy !
150 gallons is huge I'm only talking about a 12 gallon tank but 28 years has me scratching my head again. Being a 1988 motor I was thinking I would get an overwhelming get rid of it based on the age of the motor alone. I know the pump was replaced once already but I don't know when.Going on year 28 with my second "VRO" pump.
Put 1,000 to 1,200 gallons fuel and oil a year thru the system w/o incidence.
I would rather/easier keep the 3 gallon oil tank full than premix 150 gallons of fuel every time I fill up.
I felt like I was leaning this way initially and was the reason I asked on this forum. Looks like the VRO debate has no clear answer and its really just a personal choice type thing.If anybody has any doubt left as to why Premixing is the better way to go...
This might help: A lot of these VRO using engines blew up because people forgot to refill their oil oil tank, or the connections had an air hole sucking air instead of oil.
There are simply too many things that can go wrong.
The vacuum fuel pump has been around since the 1950s, is cheap , easily repaired or replaced and works good.
So "Keep It simple and mix your own".
This one has 3 wires so I guess that answers that, thxvro2 has 4 wires
The ones I owned were earlier models with the old VRO system, I am sure the newer models have improved that systemThe 1988 models are excellent motors and will last many years with proper care / operation / maintenance.
I run mine in November with ice on the water, why should I check my VRO?Now I want you to do a P M inspection every year of all those parts. In areas with freezing weather. Atta boy !
Yeah, an old employee of mine went north and became an operator for Chevron up there, equipment and trucks could never be shut off outside.Unrelated really but I saw a new broadcast once late 70’s maybe in Alaska where it was so cold they opened a can of oil tipped it upside down and nothing came out.
