zolkat
Thread starter- Joined
- Jan 26, 2012
- 10
Hey Guys and Gals, I took my Tri toon out last week and had to be towed back in as my steering neck broke on my motor, I was told that it is easier to replace the mid section, than it is to replace the neck and shaft, since the power head has to come out, I cant find any info anyplace on the mid section removal, however this is what i cam up with, make sure motor is stabilized on winch or what ever you have, Remove two upper bolts from steering neck, and 4 lower bolts, I,m good with that and it makes sense, Does anyone have any input? P.S. what do i do with the shifter rod it seems that in order to get the mid section out the lower needs to be dropped....Thanks in advance....
