wwcj101
Thread starter- Joined
- Jun 20, 2009
- 44
i recently bought a 88 venture tournament edition bass boat with a gt 150 on it. the tach voltmeter and fuel gauge were all inop. i read a few things, i talked to sammy sausage and ernest eeg. they all pointed me at the voltage reg. i checked the voltage with my engine running it was staying right around 14. and it also looked brand new.
so i get to looking at wiring under column and behind gauges. i find that the ground wires to all of them is getting 12v in run. i disconnect that lead from the ground bus and hook up a known good grnd. now the voltmeter works the tach drops to zero with the key on and the fuel gauge was doing some crazy jumping. i find the sig wire is tied directly to the ignition (hot in run) wire. i disconnected it. i think that i will be able to trace the correct sig wire because i can see them on the other end.
my question is what color is the tach sig wire under the dash when it comes out of the harness? or am i going about this all the wrong way? any tips suggestions or input will be greatly appreciated.
