Re: Back to work on sanding and grinding
Disregard the above, I beveled the holes a little more and it slid in and flush all the way around. I really should stop before I get tired.
Got the edelbrock carb installed tonight- piece of cake-I used an adapter plate that is slanted to keep the carb level and was able to remount the bracket on the rear mounting stud.
Weather is going to be great starting wen, but with my kids, I won't get home til after 6;30 each night and I can't ignore them and they aren't old enough to be much help.
So I get to do a little work this saturday and that is pretty much it til next weekend.
Engine start date is probably now going to be mid May
Now for the problem of the day . . .
I had some high pressure hoses from the transmission to the transmission cooler made and went to install them tonight . . . on the cooler side when fully tightened, the lines slide in and out of the fitting. Not sure how to fix them or if they can be used, but until I get this resolved, there is no way I can finish the cooling system hook up. I'm going to take the cooler and lines over to a friend's shop and see if he has any thoughts.
On the bright side I did get 16 feet of 1 1/4 hose for 2 bucks a foot at Boater's World (I'll have leftovers, but they are odd about cutting hose right now)
Not as productive a night as I needed, but managed to make some progress. Looks like a mid June launch is the earliest I can hope for.
