1988 merc
Fisher freak
at idle there is little water flow from the tell tale but at speed or under acceleration there is plenty any ideas???:confused: by the way it is a 9.9hp
ebrich2
Re: 1988 merc
when was the last time the impeller was changed?
Whoopbass
Re: 1988 merc
A lot of Merc's are that way. Run the motor and then remove the cover. Put your hand on the block and see if its hot. If its running hot you will only be able to hold your hand on the back of the block for a second or so. Most likely your motor is fine.
Fisher freak
Re: 1988 merc
it has never been changed at it only started at the end of last year. the outboard is all original factory parts except the power pack the prop and the seals behind the prop.
aussieflash
Re: 1988 merc
Replace your impeller $25 or wait till motor blows $1000.....or never slow down.At speed water is forced through sick impeller via obvious current.
windy5849
Re: 1988 merc
I just replaced the impeller on my 1990 Merc this year!The old one still LOOKED good,but $25 is cheap insurance against a $1000 repair bill.Change it and have fun running the boat without the worry of over heating.
M
Maxz695
Guest
Re: 1988 merc
change it before it blows up and you have impeller particals all throughout the powerhead. Most times thery cannot all be removed without ripping the engine apart.
aussieflash
Re: 1988 merc
Cmon Max,now you got me paranoid.might pull mine apart next week...lol
