1988 Mercruser 4.3 Liter Mercruser Engine S/N B779146 Model GM 262 V-6
berry7199
My son and I just got this boat last summer and changed the engine oil and stern drive oil (and impeller). We took it out for an hour or two probably once or twice a week for the whole summer. With an engine this old should be change the engine and stern oil every year? Or just the engine oil?? Thanks!
dubs283
I'd change both annually along with pulling the drive and inspecting the entire transom assembly and drive external bits, u joints n such
tpenfield
It is good to change all of the oils on a new-to-you boat. The outdrive oil will be fine for a few seasons, whereas the engine oil likes to be changes annually.
Your maintenance schedule is 50 hours or annually. Which ever occurs first
Ayuh,..... I try to do oil changes in the fall,.....
Especially the drive,....
If by some chance it picked up some water, oil is cheaper than a frozen busted lower unit,....
Scott06
Exactly- doing this has served me well for many years. Years ago my grandfather motioned taking a outboard out of his shed in the spring only to have the lower case fall apart. Had water in the lube and it expanded in the winter.
No sense saving $15 on lube. If I recall a Gen one only takes a qt ?
Also worth greasing the gimbal bearing if they still have a greaseable one.
