1988 mercury 100 HP no spark
clevecan
Hi all,
New here and see where everyone helps others so here i am.I have a 100HP 1988 merc outboard that will not start,I see the spark plugs are not fireing?
any help would be great.And or wireing on this motor or link to wireing for testing coils,statior,
thanks....
Laddies
Banned
Re: 1988 mercury 100 HP no spark
This should help
clevecan
Yes indeed thank you very much,I'll try this after work....
clevecan
With no DVA meter i'm lost on this testing thing.I did try and someone told me two test the yellow wires from stater to see they grounded when my meter was on it and touched to block.It seemed to be fine.
Laddies
Banned
The OHM readings are on the same page use them they are not as good as readings from a DVA but usually work fine.
clevecan
Ok will do.\
thanks.......
clevecan
Ok it was the stator and the power pac, the stator was only putting out of one side they said but now runs, then I put it in the water and it would not go lol, after looking at it I found the lower carb was not opening the little link
was broke so have one comming.we opened the lower carb by hand and it took off,,,
thanks all for your help...
taggers59
I have the same, no spark with my 1988 Searay/ mercury 100 HP outboard. It ran great last fall had it winterize, it turns over but no power to the plugs.
HELP!!!!
taggers59
