1988 mercury 150 xr4, 25p 5 blade prop
ebrich2
i clocked my boat at 58mph at 5400 rpm, can i get anymore speed from it if i change pitch or # of blades? 5500 to 5600 rpm is about the max for my motor. thanks
Robbabob
Re: 1988 mercury 150 xr4, 25p 5 blade prop
"is about" for the max rpm is vague. Confirm the max before you change.
If the conditions were perfect when achieving 5400, then a 1" pitch reduction will gain the final 200 rpm you are looking for. This also assumes you will stay with the same prop manufacturer and number of blades.
Good luck!
