ugadawg187
Thread starter- Joined
- Aug 18, 2007
- 165
Not sure of the yr model yet i havent pulled the serial number to check but i believe its a mid to late 80's. It goes dead at idle unless you give it some throttle & its sluggish until you hit around 2500-3000rpm. I believe it prob needs a carb job but i wanted to check all the causes of this. Compression was said to check out at 100 on all four cylinders.
