JJ-Juniper
Thread starter- Joined
- Aug 15, 2017
- 10
Mercury serial # 0B217717
I'm a new boat owner who's fairly handy, but have just started learning about 2-cycle engines. I'm trying to get this old girl back to proper working condition. I have learned a ton from reading so many posts on this forum. You guys are the best!!
So... here's my problem: Engine starts up easily, but I've found that only cylinders 1 and 2 are firing. I have determined this by doing a cylinder drop test. With engine at a fast idle, I disconnect the wire on the plug for cylinder 3, and the RPMs don't change. If I disconnect plugs 1 or 2 similarly, the RPMs drop noticeably.
I have pulled the cylinder 3 spark plug, and I get what seems to be a good, strong spark to ground when I hold in a bit less than 1" from ground. The tip of plug 3 is way cleaner than 1 and 2, so I suspect it hasn't been firing at all. I had the boat out on the water pulling kids on a tube for an hour when the overheat horn sounded. I shut down right away and brought her in for investigation. With no gas/oil in cylinder 3, I'm hoping that this was the cause of the overheat alarm. Compression in all three cylinders is between 105-108 psi.
I checked my stator, and Ohms are good for red and blue cirucits. DVA readings are both also within spec. When checking blue circuit and increasing RPMs, the voltage climbs to the 280-310 range. I do seem some flickers of readings below 100. They are very brief, and 98+% of the time, the reading is between 280-310. Is this a sign of a bad stator? I have recently replaced the power pack, as my earlier DVA tests (few weeks ago) showed the stator was good, and the pack was not. (I wasn't getting any spark before replacing the power pack.)
I pulled the two carbs out and made sure they look good. All holes that I can see are clear and clean. The float is not getting stuck. If I remove the bottom bolt from the bowl, I can get gas to flow freely when I squeeze the bulb.
I appreciate your thoughts with where I should look next! Thanks in advance!
Jeff
Jeff
