astuckey
Thread starter- Joined
- Sep 4, 2011
- 83
Hi guys, as the 2013 boating season is starting up, I was wondering, what are some common problems that these engines and drives have, and what can I do to prevent these problems? I know about all the shifting issues; my boat shifts smoothly and has a red lower shift cable, not the stock one. But other than that one, what else is a common issue? My engine is a 4.3l GM with a rochester 2 barrel carb (which was recently rebuilt because of the accelerator pump) and and an electronic ignition conversion to a Pertronix ignitor 2. One thing that I am slightly concerned about is the starter motor. Is there a way to tell if it is going to stop working soon?
One thing that I noticed is that there is some corrosion behind the mechanism that the cable attaches to, to shift the lower unit. The cable itself is nice and clean. Should I clean this, and if so, how? Or is it better to leave this alone?
Also, going to change the gear lube this year and was wondering if I should run the engine before changing it to get the oil hot?
Thank you for your help!
