1988 OMC 5.0 swapping with 1984 OMC 5.0
BTyree
I have a 1988 OMC 5.0 engine and I'm swapping it for 1984 OMC 5.0. I realized they changed the engine coupling in 1986. I'm wondering if there is a engine coupling that would connect my 1984 motor with my 1988 outdrive shaft?
Probably not. OMC also changed the drives from stringer to cobra at same time.
Why not find a 1986 or newer motor to make your life easier
Ayuh,..... Sierra makes a conversion couple, that's listed in iboats megamall,.....
Hit the parts links at the top of this page, 'n search it out,...
I ain't got time at the moment,....
Ok,... I was wrong, the retro coupler goes the other way, newer motor to older drive,....
Best I can figure, yer gonna have to use the Merc donut coupler for the 2 pc. rear seal motor,.... 18-2171,...
OMC came out with the Cobra the same time GM went to the 1 pc. seal, so there's no Cobra coupler for an older motor,...
I say find a 1986 or newer motor
