1988 OMC Cobra 3.0L engine revs/slipping
jabraham
Hello, my first post here…I recently purchased a four winns boat that has a OMC 3.0L and I took it out on the water the today and once I would get past 1/2 throttle or so the engine would rev up and sounded like a slipping clutch and the boat would not move any faster. Also noticed that the temp gauge went up to close to 220 or so. After I slowed down to a slow speed/light throttle, the temp went down. Any help or guidance would be appreciated. Thank you!
Jason
My guess your coupler is toast
However based on 220 degrees, every bit of rubber in the exhaust path is also burnt toast ( no cooling water means your exhaust goes from 250 degrees to 1200 degrees)
kenny nunez
It might be the drive coupler. Reach behind the engine and feel around the shaft where it engages the coupler. If the coupler is the problem you will get some black sticky material on your hand.
hugh g
Look in the bilge for black dust which is another sign that the coupler grenaded.
bruceb58
Sounds like a spun prop hub. A coupler would be all or noting.
jabraham
Thanks for all your input!! I will check the prop hub first and go from there. Thanks again!!
