1988 Rogue 2420
Spent Saturday working away at the hit list on the boat.
wired up the amp and radio
cleaned out a mud dauber nest
discovered the port-a-potty top tank leaks
so...... Sunday morning fixed the port-a-potty
Click image for larger version  Name:	0712200939_resized.jpg Views:	1 Size:	276.1 KB ID:	10899162Click image for larger version  Name:	IMG_3646_resized.jpg Views:	1 Size:	68.8 KB ID:	10899159Click image for larger version  Name:	0712201456_resized.jpg Views:	1 Size:	112.1 KB ID:	10899160Click image for larger version  Name:	IMG_3647_2_resized.jpg Views:	1 Size:	90.9 KB ID:	10899161Click image for larger version  Name:	0712201723_resized.jpg Views:	1 Size:	117.2 KB ID:	10899163Click image for larger version  Name:	0712201456a_resized.jpg Views:	1 Size:	288.6 KB ID:	10899164Click image for larger version  Name:	0712201456b_resized.jpg Views:	1 Size:	328.7 KB ID:	10899166Click image for larger version  Name:	0712201606_resized.jpg Views:	2 Size:	315.5 KB ID:	10899167Click image for larger version  Name:	0712201606_resized.jpg Views:	2 Size:	315.5 KB ID:	10899168
Not the greatest photographs, however its a soft splash at least.
dropped in at the Fort Hamer boat ramp which is only 3 miles from the house. good thing its close
bad thing..... its farther up the river, which means that the river gets shallow in a few places......
still have a few things on the list that need to get finished:
install wiper arm
fabricate / install cabin interior closet
fabricate /install cabin interior bulkhead wall
fabricate / install final ceiling panels
install cabin door
install cabin lighting
new anchor rope
and have a few things to fix after the soft splash:
swap NO oil pressure alarm switch for NC
re-paint the props from running aground in the muck in a manatee no-wake zone (@#$%@#@#$!@#$ shallow river)
flush the HX from running aground in the muck.......
and the most important.....swap the helm around because the bolt pattern from the new helm is opposite the old helm.... and I never checked it prior
yes..... left the dock with turning right is going left....
also need to read the plugs, think I need to go bigger on the jets on the secondaries.
tpenfield
this restoration started as a re-power pulling the old SBC on January 24th, 2016
4 years 5 months 2 weeks 3 days........
Wow . . . That's sticking with it for sure. Glad you are back on the water. :thumb:
After all of you engine and outdrive work, would you be considered one of our Volvo-Penta 'experts' :noidea:
I'm just glad to know its not a unicorn :D
and all these things will be fixed by a guy who has lots of experience
Thanks Ted....... not an expert, just a guy with hands-on knowledge
although I can tell you what gets plugged when you drive the outdrive into the muck coming off plane in a no-wake zone and take all the paint off the props......
kcassells
Sorry to hear you ran out of beer! But Looks like a great day out with the Queen and boat!
here is some of the aftermath of running aground in muck.........
I get to re-paint the props and lower part of the drive.....
mickyryan
man, tore that impeller to shreds, ahh well could be worse though at least ya didn't pop a head and were quick to shut it down.. i had to giggle about steering thing i bet that was a shocker! easy peezy stuff to take care of and now you have the boating bug again wont sit in the driveway much :)
still looking for bits of the impeller. flushed a bunch of biological debris so far. a few clam shells, some weed material
tonight pull the ends off the HX and OC
mickyryan
you know that's the part of grounding i hate the most id rather break a ear off a prop then chase the cooling system, do you have a way to reverse flush engine ?
an array of pieces of hose, fittings and hose connectors.....
emoney
Boat looks great, Scott. I'm north of you about an hour and half so I know all about the "shallows". Gets even skinnier up here.
Nothing better than a splash, soft or not. Kudos!
so...... found the impeller bits (two still under the motor in the bilge)
and rattle-canned the props
