fairshopperguy27
Thread starter- Joined
- Aug 22, 2012
- 127
Working with my dad on a bit of a project he probably shouldn't have gotten into. It's a 1989 pursuit 2000 with a 1988 yamaha 200hp model ETXG. This boat has been stored and hasn't ran for 8yrs. The original owner who we got it from fogged the cylinders and drained the fuel tank. Amen to that. So we put 20 gallons fresh fuel in, changed the lower unit oil, new water pump, oiled the cylinders with a squirt of 2stroke oil and put new plugs in. Also changed the water separator and fuel lines. Rotated it by hand for a bit then hit the key and it Fired right off! Smoked like crazy but it cleared up. Idled it for 10-15mins off and on Then came the trouble. An alarm coming from the shift controller came on while idling and it appeared that it was starting to overheat because the blue smoke turned to white and the water coming out of the pee tube was super hot. Cylinder heads were very hot too. Both remote and main oil tanks were full. And I have no trouble feeding the main tank under the hood from the remote tank, fills fine with holding up the switch. I believe the oil injection system just may not even be working? I pulled two of the oil lines that lead into the side of the carbs and there was no fresh oil in them, I blew them out with air and it appeared to just have a little bit of old blueish and brownish oil. Feeling a bit paranoid I went ahead and mixed 50/1 into the 20gallons in the fuel tank. Towed it around the block to mix up the oil/gas. After getting the mixed fuel through the squeeze ball & line, I fired it back up, normal color blue smoke, but the alarm came back on after about 3-4 mins of idling and everything still seemed hot? Any thoughts? I'm really thinking about just disconnecting the oil injection system unless I can somehow verify that it is in fact working.
