1988 Yamaha Excel 225 - Help needed
paulnels
Hi All! I have had this 1988 Yamaha excel on my 21ft Chris Craft Center Console for the last three years after picking the motor up dirt cheap because it had a bent prop shaft. After repairing the bent prop shaft, I had an amazing running motor for under $500. After running the motor for two years with minimal issues, I was running across a lake at about 4k rpm and the motor seized up. Upon tearing everything down, I found that the piston ring on cylinder 4 had caught on the exhaust port. After further inspection, I found that the oil injection pump had gone bad, resulting in engine failure.
Instead of trashing the motor I found that the damage to the cylinder wall was not nearly as bad as I initially thought. I took the block to the local machine shop and was able to clean and true of the cylinders without needing to re-sleeve or do more than a good boring on them. I ended up making the choice to completely rebuild the power head. #covid19project. I did not plan on the rebuild taking more than a month but life happened and I finished the rebuild about a week ago, 13 months after pulling the power head......... While for most organized and, well smart people would have taken a million pictures of where every wire, ground, bolt, nut, and washer went; I did not <insert facepalm image here>.
I now have the power head mounted, controls, fuel system, and electrical wires ran to the best I can remember and from the limited pictures I have found on the internet. I have every single manual ever made on this motor, to include the factory Yamaha service manual. Even with these resources, I feel like I am missing something somewhere. The engine turns over and I have power to the rectifier and CDI, but I am not getting any spark. I need some help and ideas on where to go now. My thoughts are:
  1. Missing ground or other connection
  2. Bad CDI
  3. Bad YMIS
TLDR: Motor blew up; I rebuilt motor; stupidly did not take pictures and have no clue what I am doing; engine turns over but no spark; need help please!
Thanks for reading this novel of a post!
QBhoy
It would be amazing if it was just that the lanyard kill switch had been pulled ! Thought I’d throw the obvious one in there.
On a side note…I think it’s extremely rare and almost unheard of for a yam like this to have it’s actual oil pump fail. More common might be for the fittings, pipes or delivery system to fail perhaps.
paulnels
Ok, figured it out! When I rebuilt the motor I replaced the each ignition coil with brand new aftermarket coils. Problem is the were much higher resistance coils than the ones from the factory. The were 6-700 ohms vs 250-300 ohms with the originals. Put the original ones on and fired right up.
I am going to post some pictures of some wiring diagrams for any other poor sap like me that may need them in the Internet future.
3A800D86-3437-4EEE-91C8-A3407BD47539.jpegE937F11E-603C-42E5-AA2C-CF199DF71447.jpegA7013BF1-A6D3-4C7A-B15C-D9DD104023C7.jpeg962B5799-067D-4220-825F-243731AB142B.jpeg
