1989 120hp johnson compression test results good or bad
Bob427
i bought this motor as a winter projet to hopefully hang on my boat come spring time
so i took compression today and here are the results
#1 120 #2 120
#3 120 #3 120
all even how ever number two cylinder takes about two times more revolutions to come up to psi
now motor has sat for a long time as it will definatly need carb kits
it does have good blue spark on the spark checker
just wondering if i should be concerned about #2 cylinder
thanks Bob
Bob_VT
Re: 1989 120hp johnson compression test results good or bad
You are golden! No problems...
Consider an impellar kit too!
Bob427
You are right forgot about the impleller
Thanks
Solittle
If this is a salt water engine replace the thremostats.
cdn-pk
winter project??? no way, change plugs, impeller, fuel filters and your ready to fire it up! ;)
Bob427
it really needs new paint bad if it wasnt 21degrees outside it would be running on the stand lol
