Mburucuya1
- Joined
- Aug 19, 2010
- 6
I just bought the boat, 1989 Stratos 279 FS, already replaced the water pump, clean all three carburators, replaced fuel filter, clean fuel tanks,replaced spark plugs, and three ignition coils(used), bottom cylinders seems to get a little spark after the engine run for a couple of minutes, I installed a good know coil on the bottom right cylinder, please help. Compression with cold engine is 90 PSI to highest and 88 PSI as lowest. Already tried in the river, throttle goes to 3/4, if you try a full throttle the engine seems to surge and try to stall. Thanks.
