1989 15hp Gamefisher outboard 225.581501
rdunehew
This is my first Boat motor I've ever had experience using. I'll tell you it seems to run smooth, it can be hard to start at times but usually its not a problem. I recently took it to a local outboard motor repair guy just to get it serviced(replace water pump impeller, change oil, etc) He called me back shortly after dropping it off and said that one of the cylinders does not fire. I went over and checked it out, and for sure, it is currently only firing from one cylinder. Is it possible this whole time ive had it(one year) that the motor has been running on one cylinder? With just me in the boat I feel like I'm cruising farelly well around the lake. When I have one or more persons with me it really bogs down, but runs smooth. Any help would be appreciated, Thanks
Ryan
