1989 25' Invader cabin crusier fiberglass stress cracks
dmiles452
Would it be normal to see stress cracks in the gel coat of a 1989 Invader cabin cruser? The cracking is in a radial pattern around the stern drive on the transom.
KJM
It could very well mean a rotten transom that's starting to flex. When (if) you find a rotten transom, prepare for rotten stringers and such as well. Hope for the best and prepare for the worst. Good luck!
KJM
Another thought would be to check the engine mounts and what they rest on to make sure there is no play there allowing the motor to move slightly and putting extra strain on the transom.
dmiles452
There is no movement in the engine, I have checked that several times
tpenfield
34 year old boat. . . normal went out the window a while ago. Stress cracks around the transom are usually signs of trouble.
