Definitive
Thread starter- Joined
- Apr 9, 2010
- 4
I picked this boat up for very little so i dont mind putting in a little work, im looking for some opinions from those of you who have repaired cracked iron blocks in the past.
Any help you all can offer will be much appreciated
the details.
I purchased with the information that water was leaking from engine up under or near the intake at or about center from front to back while running, and that the temp gauge ran normal and there was no sign of water in the oil.
I brought it home and after about and hour of removing parts i found the crack.
The size and shape of this crack concerns me, its very high on the block running lengthwise yet vertically entering the water chamber, I removed the thermostat and ran the garden hose at low pressure which was enough to jet water out of crack in an upward arching motion.
I can understand the method of repairing the block but im thinking the out side might not be the only problem, wouldn't the inside be damaged as well?
This crack is located about 10" above the "freeze plugs" yet there appears to be some rust stains from a seem line in the paint about 2" below the same plugs causing me to think there may be 2 cracks running parallel with each other
So what if I made the repair, whats the chances that the giant slab of iron could pop off while in use?
being the sale is final and a refund/buyback is not an option, what would be suggested that I do?
Thanks in advance
the details.
Thanks in advance
