1989 3.7l alpha 1 leaking water @ outdrive on test muffs
cosmic coho
just replace impeller on alpha 1 and when run on test hose, water is flowing good thru exhaust, dribble hole, etc. but also some "pin-hole" leaks from between upper and lower units. used no gasket or sealant here as there was none upon disassembly. anyone think I should be concerned with this....everything else seems great. thanks
