Beer Float
- Joined
- Aug 24, 2003
- 19
Hello,I just took my boat out this weekend a 1989 23'Omc 351 king cobra for the first time this year due to high water at resivoir,anyway after I let the boat get to normal operating temp. and cruised for awhile I increased the speed a tad bit about half throttle to be exact seemed to be running fine and out of the blue the engine just seemed to lock up and it died instantly no hesitation whatsoever,we tried to fire it back up but all that happened is a click the crank pulley didnt want to rotate so after a while I tried to raise and lower the outdrive didnt make a whole lot of difference but finally it did start but would die almost immedietlly it acted like something was holding the engine from starting like siezed berrings on a engine component like water pump ect. I am now thinking it is a big possibility the u-joints are wore out, I remember in earlier years after shutting engine down and trying to restart and getting a click then when I raised the lower unit and lowered it again it would then start and no more problems until now. After towing it back to the trailer and getting it home I put the ears on it and fired the motor started right away bot sounded kindove hesitant ecspecially in deexcelaration it would often die then when I started it and left it to idle for awhile I heard it coming and going a knoking sound that seemed to be coming from the upper part of the outdrive I placed my hands on it to feel the vibration,THE ENGINE WAS IN NEUTRAL AT THIS TIME ? does this make since for u-joints? also on a Omc king cobra outdrive like I have has a cover on the top that reveales the water pump shaft USER P.V mentioned this somewhere on this site he said you could see the gears and if the oil was at the correct level well I took my cover off and gears didnt look bad but absolutelly no oil? what is the deal with this? I thought you were suppose to take the vent screw out of the lower unit and put the fluid in the bottom screw hole and squeeze oile in until it comes out of the vent hole then it is full isnt it? is there a different resivoir in this outdrive? there was no water in this area so it dosnt leak. So I guess what I am trying to figure out here is does this sound like a u-joint problem? does this water pump shaft in the outdrive spin when the throttle is in neutral I would guess so but not sure and should I have seen fluid under this top cover there are berrings in there? and if so how to fill it there are four 3/8 bolts holdin the cover on. <br />Thank you and any help would greatly be appriciated.<br />P.S. how hard is it to remove this outdrive? I have some mechanical expirience,Just the six bolts and the two hydralic arms or?
