ready4lake
Thread starter- Joined
- Jan 26, 2012
- 78
I have a 1989 bayliner with a 4.3 omc engine and cobra outdrive. I recently installed a rebuilt engine from a local boat owner. I had it on the lake yesterday and watched the temperature guage as I always do. After 10 minutes of cruising the engine was smoking hot. I opened the engine cover and felt the exhaust manifolds which were still cool enough to touch but the rest of the engine was burning up. I shut it down and paddled back to the ramp.
I just started the engine today on muffs and it is still giving the same results. Checked intake pump and impeller was good. It is brand new by the way. Checked water flow to the thermostat housing and all was good. I also pulled the outdrive to check for blockage in the exhuast but there was a good flow of water with the hose connected straight to intake hose.
I pullled the thermostat and heated it up and it is fully open at 155-160 according to my temp gun.
I pulled the circulator pump and there is no play in the shaft and blades look good with no corrosion, but it is pretty old so I am going to order a new one. I will also get a new thermostat since they are cheap.
It seems that there is some blockage in the engine block or somewhere in the engine because everything else is flowing as it should. Is there anything that I am missing here? It has become a real head scratcher.
