nwboater45
Thread starter- Joined
- Sep 6, 2012
- 91
I have a 1989 MCM 470, 3.7L that I just installed dual batteries on with a Perko switch. The switch selection is 1, 2, All. The reason I am not posting in the electrical forum is that I want to confirm the charging system in my boat. I also still have the stator and not an alt.
So according to service manual #8 there is an orange wire that goes from the voltage regulator to the starter post. Is the wire that is sending the charge back to the batteries? Or am I not reading that correctly?
The way I set up the dual batteries is (one on each side of the boat), batt 1 & 2 ground wires are going to the engine block in separate locations. Batt one poss is going to the perko post 1 and batt two is going to the perko post two. The starter wire is going to the common post. So basically the same in the attached diagram. Batt one is the starter batt and batt two will be for accessories.
So the question I have is, so no matter what battery I have it switched to that battery will be the one charging, correct? Is there ever really a reason to have the switch selected to all? I read one thread in here that might be bad for the system.
