1989 48 HP Johnson Outboard No WOT With Air Silencer On?
Stumpalump
Solinoid with the little red lever could be bad and pulling fuel when it's not supposed too.
Highdog1
Stumpalump - I did check the solenoid and think it's okay. Pulled hoses (had engine running) and gas didn't spurt out til I pushed key in , let key out, it stopped.
Thanks
Stumpalump
Thanks
Could be leaking internally. Cracked ones cause fits. Plug the fuel line too it.
Highdog1
No Title
Thanks Fed. Been out of town a couple and weeks and finally got a chance to tear it down some more. Took the lower unit off cuz I had to order and replace the o ring and propeller shaft seal which was leaking gear oil, and sure enough there was oil leaking down the inner exhaust housing. So I pulled the power head to check the lower crankshaft seal and there was no leak there. Seal is fine. I checked the one under flywheel a while back and its fine. But there looks like a hole in the exhaust port inside the block. I've attached pics. Is that normal? It's leaking oil pretty bad around the bolt there and power head gasket. I rebuilt this motor almost 2 years ago and never noticed it before. Looks like it was drilled out and re tapped . There was a spring insert in there.?
Thanks
jakedaawg
The "spring insert" was most likely a "heli-coil". It's a previous repair or even used in oem manufacturing by some.
Highdog1
Thanks jakedaawg - any suggestions on how to fix that hole there?
