Donzi GT250
Thread starter- Joined
- Apr 22, 2011
- 110
I noticed that when shifting out of gear on my 1989 5.7 cobra the V notch cam doesn't move far enough up or down to engage the shift interrupter switch and yes the boat is in the water so there is a normal water load on the prop.
The V notch cam moves some while shifting but not far enough for the roller on the interrupter micro switch to cause the RPM to drop.
If I trip the switch manually it works as it should and interrupts the RPM's for 5+ seconds as long as I hold the switch in the activated position.
I also have the newer style shift module which bypasses the two front over-stroke switches.
It seems that during shifting there isn't enough tension being placed on the interrupter switch cam (by the transom shift cable) to move it far enough to engage the interrupter switch in either direction.
Should the interrupter cam always move far enough to engage the interrupter switch during every shift out of gear or only if the shift tension is high enough to move the interrupter switch cam ?
I just had my drive rebuilt and the company that rebuilt the drive hones the internal shift detent lever in the lower drive case to lessen the amount of force needed to move the vertical outdrive shift lever. So maybe the shift lever movement is so smooth and easy to move that it doesn't create enough tension ( on the transom shift cable) to move the interrupter switch cam enough to engage the shift interrupter switch.
Also I have had a new style transom shift cable (lower cable) installed this past spring and the shift interrupter switch roller always centers in the center V notch of the cam as it should when the drive is in gear and in neutral, so I think the lower cable is adjusted properly.
Any insight into this situation as my OMC oem factory manual doesn't give specific info. about this situation would be greatly appreciated.
Thanks for taking the time to read this.
