1989 5.7 Quadrajet to Edelbrock 1409 swap help
Status
Not open for further replies.
vetting
I have a 1989 mercruiser 5.7 with what I'm pretty sure is a Quardrajet carb on it. I'm tired of fighting carb issues every other year and really dont have the patience to deal with a carb rebuild. So I want to upgrade to a Edelbrock 1409 carb. I'm just wondering if Im going to need an adapter plate and if I need any brackets for the throttle or not. I dug up some old pictures for reference.
Also, I know that I'll have to redo the fuel line. I would like to put in a flexible line to make it easier to working on the motor - like taking the inline filter off and being able to remove the valve cover for rocker adjustments. I was thinking about putting braided hose in - do you know what size the fittings are?
Ayuh,.... The 1409 is a dual patterned carb, so it should bolt right on,....
The linkage should/ might work, with little to no modifications,....
The fuel line from the fuel pump to the carb is 3/8",....
Rick Stephens
The cable bracket will drop right on. You'll either have to make up a steel line or use marine fuel line with 'push on' fittings/connectors. Your autoparts store will have the fittings.
Fishermark
If you use rubber hose, just to be more specific, make sure it is marine type A1.
NHGuy
If you use flexible hose do yourself a favor and get some insulated padded clamps to keep it from bouncing around. Especially near the belts and pulleys.
vetting
So I dont need a Edelbrock 2696 Four-Hole Square-Bore to Spread-Bore Carburetor Adapter?
Rick Stephens
That adapter goes the other way. It takes a square bore intake and adapts it to a spread bore carb.
Generally speaking, a square bore carburetor like the 1409 has dual mounting/screw holes and can be attached to either a square bore or a spread bore intake. It is not quite as efficient sticking a square bore carb on a spread bore intake. Or vice versa, using an intake designed for a spread bore with a square bore carb is not quite as efficient. That efficiency is lost through minor difference in airflows as compared to using intake and carbs designed together.
vetting
So I guess I dont understand when one would even use that adapter with a 1409 then but it comes up in almost every post out there regarding mercruisers and 1409s. I was under the assumption that you need one unless you already had a weber cab (91+) which is already hooked to a square bore intake.
Rick Stephens
So the way you phrased that was confusing to me. Looks like what you said was Square-bore (intake) to Spread-bore carburetor.
I do not believe you have to have the adapter for the 1409 to fit the spread bore intake because the carburetor has both sets of screws. I did not try to do that though. I have a square bore Performer intake. And I do not know what efficiency is lost via either method: A) square bore carb directly on spread bore intake or B) through an adapter plate.
Fishermark
I went from a Quadrajet to an Edlebrock square bore carb on my 56. I have the Performer spreadbore intake. I did not need the adapter... but it is close. As long as the the barb and gasket covers the opening then you are good. You will have to take a look and see once you get the carb.
carrera205
I'm looking at doing this swap also! Anyone have pics of the 1409 on their Merc 5.7 with the bracket and cables setup?
Status
