1989 5.8 shift problems
talies13
Re: 1989 5.8 shift problems
Withe the esa unplugged it does the same thing. I am guessing that my timing is off. I will adjust timing Monday and see if that helps with rpm issue. I am allso going to pull drive and double check the shift cable.
wrench 3
I gave you the timing and idle RPM specs back on post#17. Make sure the idle speed is down before setting the timing.
talies13
Update... esa is shiftng great now. timing was off and idle was to high. idle has to be no more than 650. thanks for the input as allways
