woodrow2929
Thread starter- Joined
- Sep 29, 2016
- 41
Ok so I know that there are plenty of post on here for this very issue and I’ve done some research but I’m just confirming some things. But I have a 50hp force with a tilt trim I added myself, everything was running and working fine until one day when I got off the lake I thought I had lifted the engine all the way up to trailer the boat and my dad realized the engine wasn’t up at all and that’s how we discovered that there was a leakdown.
I have realized that that it’s not in the trim part of the system and when you let it all the way down to the trim part it’s doesnt go anywhere but when you let the weight get on the tilt tube (gas shock looking thing) it slowly lets down and make a slight noise when letting down around the tube, I guess my question is would be issue be in the tube or in the motor where the check valves etc is at? And can I take the tube off without having to take the whole engine off? I have a prestolite motor assembly (has 4 Phillips head on the bottom) any advice would help.
if it is that I have heard there is a guy on here that is a pro at this stuff rrit I believe?
thanks guys!
thanks guys!
