1989 50hp Force power trim relay installation
woodrow2929
ok so I just take the red rocker switch off and spray some wd 40 in it?
jerryjerry05
I believe?? that the switch can be removed and sprayed with WD.
​You might have to remove the handle completely.
Some have a set screw on the bottom?
​Some have a screw under the center plug on the handle?
​Just removing the red thing, you might not get it back together?
woodrow2929
Yeah I messed it completely up and have to get a new handle now. The red rocker switch wont stay in the slot and keeps falling out and when I do get it in there you have to press it really hard for it to do anything. But on a good note everything does work and will work once i get that fixed lol!
