tigerhunter
Thread starter- Joined
- Oct 1, 2008
- 8
Hey all,
I added a tell-tale to my motor last year and everything was great. My last trip out the motor stopped peeing above idle. I put it up for the winter and just replaced the impeller last week. The old one was dry-rotted and cracked.
I put everything back together and started it up. (in a big bucket of water, not muffs) Now it won't even pee at idle, and water is leaking out of one of the four bolts that holds the lower unit. I tried to tighten the bolt but if I go any tighter it will strip or break. I searched and read that there is no seal between the two.
Could this leak be why it is not peeing and should I just take off and reset the lower unit?
I am lost and don't want to run it too long without it peeing. I have a big trip planned for saturday and have school and work both full time and could use some help.
Thanks in advance,
Trevor
Thanks in advance,
Trevor
