Re: 1989 50hp not starting and prop spinning freely
If the engine is in neutral, the prop should spin freely if turned by hand (engine off for heaven's sake). If it is in either forward or reverse you should not be able to turn the prop by hand.
No -- the engine does not have a shear pin. In neutral you should be able to spin the prop freely by hand but not if the shifter is in forward or reverse.
Yes - there are two safety switches. #1) is in the control box so the engine will not crank unless the throttle/shift lever is in neutral. (You do know the difference between "won't crank" and "won't start" don't you?) #2 safety switch is the kill switch which is the lanyard you attach to your person so should you be pitched from the boat the lanyard pulls the kill switch and stops the engine. Unless that lanyard clip is in place (switch is located under the ignition key) the engine will "crank" but it won't "start". Depending on the year of your engine it may not have a kill switch.
