One4DelRey
Thread starter- Joined
- May 15, 2008
- 21
was out fishing this past friday and everything was working fine. motored to my spots, did a little troling and no problems. when returning to dock coming out a no wake zone as i accecerated it happened. bam- high rpms, i quickly shut it down. i thought i spun a prop. trimed it up, prop was still there, oh s#it! tried to start it back up, now no power double oh s#it! was towed back to ramp. trim didnt work, so needless say it was not fun towing it back home(now i have some skeg issues). this saturday i went out to check things out- low and behold, now i have power. started motor and still no forward or reverse. trimed it up, checked lu oil and it was a little milky with some very small metal debris on magnet. dropped the lu to check things out. there was a thick milky slime on the impeller housing. checked impeller- it was ok, not great fins bent, butt not broken. refilled lu oil then putt everthing back together. started it up and now no tell tale at all (in the past it took about 15 to 20 seconds to pee), and still no forward or reverse. took a break, then back to check some other things out- now no power once again....... anyone have any advice. i know i have lu issues, but whats this power issue- works, then not?
