FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Is the needle valve supposed to be somehow attached or hooked to the float linkage? I am frequently finding the needle valve stuck in the closed position so no fuel is getting into the carb. Any schematics or details would be greatly appreciated.
If you just recently replaced the needle valve this can be a common problem. Sometimes there may be a small burr sticking out at the bottom of the rubber part where it meets the needle.
Also, if it is newly replaced the valve may stick until the it gets saturated with gas/oil mix.
This engine has two carbs. Neither has had needles replaced anytime recently. Many people have told me that there should be some kind of wire or clip that connects the needle to the float linkage to help pull the needle down when the float drops. I can't find a schematic that shows this for this engine. Which is correct?
