bayliner_fox
Thread starter- Joined
- Aug 15, 2009
- 8
hello i have a 85hp force that has had its problems this year.boat didnt want to idle so had the mechanic clean the carbs.he then said he need to adjust the timing to make it idle. I thought it idle too fast so he then turned the timing down and adjusted the carbs.The boat still likes to die when you pull back to netural.(randomly). and it likes to cut out (randomly) when you hammer it.sometimes it would even die when you coming out of the hole. this is all random what i know is normal is the boat did do 45 Before and it would jump out of the hole and plane out faster then it does now. and now it would only top out at 40 no matter how many people are in the boat.good comp. something seems wrong. something must not be working 100%. any ideas would be nice. thanks for now
