KRISFLORES94
Thread starter- Joined
- Jun 9, 2017
- 14
hi everyone I am new to the group and I have searched everywhere to try to find help with my problem.
I was given a 16.5' Quantum bass boat with the 85HP Force on it I had to replace the carpet and a few board and while I had it apart i cleaned the fuel tank best i could due to it had been sitting for 5 years. first time i took it out it ran great after some minor adjustments to the throttle linkage. the next time I went out i had a carb start leaking out of the over flow hole so loaded up took it home and cleaned the carbs(overflow due to trash in needle valve) changed fuel filters and line out as well. Reset the IAS to just a little over a turn out and got it running smooth but when i take it out it now runs fine for a maybe 2-3 mins at idle then dies and wont restart till i reprime the fuel system. At wot it runs great for about 15-25 secs then slowly dies. Replaced fuel pump diaphragm primer bulb and still had the same problem the next time i took it out. I know this is a big nono but i rigged up a electronic fuel pump for test purpose to see if was lack of fuel like i suspected and it ran great i just dont want to run that for safety reasons. I have a clear filter between the pump and carbs and at idle it barely drips fuel when in neutral giving a little rev it will fill the filter up but once dropped back down it sucks the filter dry so i am kinda at a loss here i feel like it might have a idle to low or something??
