1989 85hp force won’t start
MoldMoney
Hey folks,
Looking for some help my 1989 85hp force will not start after carb cleaning. The motor begins to kick then fizzles out after a half of a second. Outboard ran before cleaning (some minor hard to start occasionally issues) I’m a novice but handy but no clue where the issue may be. Could it possibly be the linkage tower? Idle screw (currently set to 1 1/2 turns out) ? If anyone could help that would be much appreciated!!!
jerryjerry05
The idle is set using the towershaft linkage. The "idle screws" are for the air/fuel mix at slow speed.
The air screws are usually set at 1 to 1 1/8 turn out. Most will run at that setting, but some need to be set more open than that. One customer had his set at 3 turns out???
A "kick" or backfire, cough, stutter means it's getting too much air or fuel.
Before the posts start is 5 "self-help" posts that you should read.
