1989-90 bayliner 2159 hardtop.
mickyryan
so today i took and ground out all the stress cracks on the port side,removed decals and ground down some patches i had done where old antenna was, then i started on fridge area , looked like several different fridges and hacks had taken place so i figured when i put new fridge in 12 volt model i would fix it right, I'm almost up to final fairing and gel coat on that piece and then i just need to finish sanding and can start painting :) still undecided about gel- coat or paint, gel coat is so easy to work with :)
mickyryan
[No message]
oldrem
Moving right along young man. Do you have a target date for the splash yet?
mickyryan
not even , lol imho there is threw sections on this boat the roof the helm cap and the hull all three have lots left to do, kinda taking my time because this was a dream boat of mine when i was around 18 the one i remember was a alaskan bulkhead
chevymaher
I like it the fact it is your dream boat. I can't wait to see what you do with it.
mickyryan
so today i was working on the fridge area more and ugh this humidity is slowing my resin down, hit it with a heat gun and seemed to help, guess ill go higher with the mek i was keeping at 1% cause here in florida it goes off so fast but with 90 % humidity ....
mickyryan
yeah, thats what i was fearing i kicked it up 2 % it seems to be slow but going :) ill check it in a few and if i got to ill assist it with as heat gun again
mickyryan
if i only had one:) hmm i wonder if she has one hiding anywhere:) , meh i mean after the dishwasher i cant see a problem with it:) on another note 2.% seems to be the sweet spot :)
sphelps
Yeah your still breathing after the dishwasher so you should survive almost anything ..
mickyryan
lol,Sam! so today got rest of boat sanded , anyone ever needing to sand around engine boxes or raised lips on bait wells a hollow pool float works well just cut it then put adhesive sand paper on it and go ! also made various sanding tools for these edges the boat has, i think i got it, but tomorrow is a new day!
I will go over entire thing to see that i got everything strait smooth,then i will wash it several times
then i will coat it with raptor liner semi smooth and thinned and give it two weeks to cure before going in and taping off the areas that i want a rougher pattern.
I have battled back and forth and decided to stick to my original plan over gel coat, its easy to work with but then i haven't sanded it past 150 because my plan all along was to use raptor.
mickyryan
well... i went with gelcoat... hoping i didint make a mistake but i think its coming out good :)
thinned 8% and shot at 28 psi with a 2.2 hvlp gun nothing but gelcoat and hardner at 2% with 8 percent reducer and wax fgci gelcoat with wax color is nason fleet cream
